snipes2013
Aug 14, 2020Aspirant
Readynas NV Sparc wont boot
Hi I have an old readynas NV i came to use today and its not booting. no lights no nothing. not sure whats happened.....can anyone recommend some troubleshooting tips? Cheers Neil
snipes2013
Brilliant thank you I’ll have a look tomorrow at that. You are right it’s old but served me well. Time for an upgrade just need to get it working long enough to copy everything off it :).
Sandshark
Aug 14, 2020Sensei
If you have a spare ATX supply, or one you can "borrow" from a PC long enough, the adapter cable will allow you to power it long enough to download the contents. Just do your best to keep the airflow moving through the NAS, sealing the gap for the cable with masking tape.
If it turns out it's not the power supply, Netgear does have a way to use a new OS6 based NAS to recover the data, though they do charge you. The current problem is availability of the lower range NASes. I do not know if Netgear offers that support on a used unit.
- snipes2013Aug 15, 2020AspirantI assume I will have to move the pins of the power supply to match the pin out? I’m hoping I can power it and retrieve the contents then get new :)
- StephenBAug 15, 2020Guru - Experienced User
snipes2013 wrote:
I assume I will have to move the pins of the power supply to match the pin out?If you are using an external supply, you'd need an extension cable anyway. You can make the changes in the extension cable.
snipes2013 wrote:
I’m hoping I can power it and retrieve the contents then get new :)If you get a new ReadyNAS you can also work with support to temporarily mount the volume in the new NAS so you can offload data. https://kb.netgear.com/29876/ReadyNAS-Migrating-disks-from-RAIDiator-4-1-or-RAIDiator-5-3-to-ReadyNAS-OS-6
Another option is to connect the disks to a PC and use R-Studio ( https://www.r-studio.com/ ). You can connect the disks with SATA, usb adapter/docks or a suitable USB enclosure.
When you do get running on a new NAS, I suggest putting a backup plan in place for it.
- snipes2013Aug 15, 2020AspirantI do have a backup plan, but as usual never actually got round to implementing it.....it’s the usual problem never give it a second thought until it all goes wrong. Thanks for your help all I’ll let you know how it goes :)
