snipes2013
Aug 14, 2020Aspirant
Readynas NV Sparc wont boot
Hi I have an old readynas NV i came to use today and its not booting. no lights no nothing. not sure whats happened.....can anyone recommend some troubleshooting tips? Cheers Neil
Sandshark
Aug 14, 2020Sensei
The most likely cause is the power supply. They do tend to last a long time, but your NAS is quite old. If you have a multi-meter, there is a 4-pin UART connection on the back (may be covered with a sticker). Check all the pins to chassis ground. If none have voltage, it's likely the supply.
Note that while the power connector looks like a standard 30-pin ATX, it is not. But you can make an adapter cable or modify the connector. The pin-put is attached to a reply in this message: Inexpensive-power-supply-replacement-for-legacy-4-bay-Readynases. Here is a nice how-to on using a standard Flex ATX supply: Readynas-NV-frugal-power-supply-replacement , but he failed to replace the -5V (white wire), which should also be done. Maybe his supply didn't have one.
digidogian
Nov 29, 2020Aspirant
I have an NV+ that popped a PSU recently. I did not find this post until after, but I would like to comment that I did use a "standard" ATX 20pin PSU and it seemed to power up and run just fine.
Now I may have toasted something without realizing it, but I was able to peel almost 5TB of data off it without issue.........
I wil certainly modify my permanent replacement for the unit. Thank you for the pinout info.
