rusyus
Feb 22, 2017Aspirant
ReadyNAS NV+ v1 won't boot, can't recover data - need help
My NV+ version 1 is stuck booting. its a very old one, bought about 10 years ago. Bought new, but for some reason it does not have any serial number on it. Was working fine for a long time, t...
- Feb 24, 2017
Hello rusyus,
You may need to get in touch with support if this is the case. Data recovery contract may be needed too.
rusyus
Feb 24, 2017Aspirant
OK thanks. Do you have any phone numbers for me? (Other than general)
JennC
Feb 27, 2017NETGEAR Employee Retired
Hello rusyus,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
