Evil_Underlord
Oct 31, 2022Aspirant
ReadyNAS NV+ v2 - can't connect SSL_ERROR_UNSUPPORTED_VERSION
ReadyNAS NV+ (I believe v2) Firmware 4.1.6 Raidar 4.3.0 Connected via cable to router Laptop with WiFI, Windows 10 This all previously worked fine, and I don't touch it very often. More r...
- Oct 31, 2022
Firmware 4.1.6
Although it might have a v2 label on it somewhere, it is a v1 NAS (using a sparc CPU).
V2 ReadyNAS run 5.3.x firmware, not 4.1.x
More recently, I can no longer connect via Windows File Manager.
Trying to connect to the NAS local IP address via browser gives me an "SSL_ERROR_UNSUPPORTED_VERSION" error suggesting that browsers no longer support TLS 1.0
They do support TLS 1.2 and TLS 1.3, but dropped support for TLS 1.0. Unfortunately, that is what the NAS uses. You can find info on what to do about this here:
Basically, you can
- use internet explorer
- use Edge in IE mode
- use an old version of firefox
Once in, you can modify virtual.conf to let you access the NAS using http (unencrypted, so not using TLS at all).
Oct 31, 2022Guru - Experienced User
Firmware 4.1.6
Basically, you can
- Evil_UnderlordOct 31, 2022Aspirant
Thanks, this is great. I haven't gotten Edge/IE to work yet, but at worst, I can find my adapter, connect directly to the NAS, and fix the SSH access for the future.
- StephenBNov 01, 2022Guru - Experienced User
Direct connect won't help. This has nothing to do with wifi or ethernet.
If you do have ssh enabled (linux command line, it is not https), you can still use that, and make the virtual.conf change I posted in the other link with vi.
