jabbott
Aug 27, 2015Aspirant
ReadyNAS NV+ v2: Adding a new disk issue
Have three WD Red 3TB drives running XRAID2 (redundant). Provides 5.4TB of space. Added a 4th 3TB WD Red, but not adding to the overall space. Checking the status, the log reports new disk detec...
Aug 27, 2015Guru - Experienced User
Perhaps try removing the new drive and reinserting it (with the NAS running).
- jabbottAug 27, 2015Aspirant
Yup ... tried that. Rebooted and then tried again. Unfortunatly, didn't fix the issue.
Still at bit of a loss as to what to try next.
Thanks
- StephenBAug 27, 2015Guru - Experienced User
Perhaps wait a day or so, and see if someone from Netgear wants to take a look (or look at logs).
One option of course is to do a factory reset, but that requires rebuilding the NAS and restoring the data.
You could also try a couple more reboots, and see if the process starts.
- JennCAug 28, 2015NETGEAR Employee Retired
Hello jabbott,
If you have enabled email alerts maybe you will also be able to get more details about the expansion. See article:
http://kb.netgear.com/app/answers/detail/a_id/20981/related/1
Another option is to backup all the files then factory reset to get fresh install with all the 4 disks.
You may also try contacting support center at 1-888-NETGEAR (1-888-638-4327) where they will get an L3 remote in, this however requires a per incident support contract.
- CholoUniverseOct 14, 2015Aspirant
Have 3x WD Red 3TB
Added 1x WD Red 4TB
Volume expansion seems to have failed: Wed Oct 14 07:42:25 PDT 2015
Then had a power outage tonight: Thu Oct 15 00:42:33 PDT 2015
What would cause the failure? It was not switched off or interrupted... ? Is there any more information I can get from log files?
Thu Oct 15 00:45:07 PDT 2015
System is up.
Incompleted file system expansion detected. Resuming...
Volume expansion failed
Mon Oct 12 16:40:53 PDT 2015
Volume expansion started. Do not interrupt the system during this time. When finished, email notification will be sent to the alert contact list.
Mon Oct 12 16:40:41 PDT 2015
New disk detected. If multiple disks have been added, they will be processed one at a time. Please do not remove any added disk(s) during this time. [Disk 1]
Sat May 23 16:18:57 PDT 2015
System is up.
