ReadyNAS312
Jan 23, 2024Aspirant
ReadyNAS NV+ V2 Disk Error, But Not Showing Which Disk?
I have a ReadyNAS NV+ V2 with 2 x 2TB (bay 1 and 2) and 2x 3TB (bay 3 and 4) running the most recent firmware. It's had a panic attack and 3 disks showed up with a first aid icon, this then boiled...
Jan 23, 2024Guru - Experienced User
I suggest downloading the full log zip.
If you have trouble figuring out what's in there, I'd be willing to take a look. Put the full zip into cloud storage (dropbox, google drive, etc), and send me a download link in a PM (private message). Make sure the link permissions allow anyone with the link to download. You can send a PM using the envelope icon in the upper right of the forum page.
Maybe also power down the NAS and test the disks in a PC with vendor tools. Label them by slot as you remove them.
