Untamedgeek
Jan 29, 2017Aspirant
READYNAS NV+ v2 HDD upgrade issues
Good morning everyone
I was hoping to not have to ask as I'm guessing it already been asked. However after some time looking I'm not able to find answer for my needs (or own personal stupidity).
I'm running a RND4000v2 - READYNAS NV+ v2 with 1TB drives in bay 1 & 2 and they are close to capacity. I've purchased 2 new WD RED 3TB drive to replace them. I know I can use bays 3 & 4, but I wanted to upgrade 1 & 2 first. When I hot swap bay 2, after leaving it to do its thing over night, it just tells me its unprotected and hasn't performed any sync. The drive is recognised in RAIDar and within the dashboard the drive is green. Do I need to then swap out bay 1 for things to return to noraml or am I going to have to do a factory rest? If I were to use bays 3 & 4 as expansion what would happen when 1 & 2 reach their limit?
I like I've said I looked on here and read the documention and its turned into a mine filed.
All help and comments are greafully recived.
If the volume is unprotected, then your data is at risk. You shouldn't pull drive 1.
What firmware is currently running on your NAS?
Also, it would be wise to make sure you have an up-to-date backup.
- UntamedgeekAspirant
Hi StephenB
Thanks for the responce. Firmwares up to date (was the first thing I checked but I will check it agian just to be sure tonight). A back is run every night to an external drive and that is being upgraded to a larger on to.
I think what I was expecting is that by replacing bay 2 it would resync, I could then repalce bay 1 and this would then recover/resync from bay 2. Giving both drives the new 3 TB size.
However from what I've read it sounds like it will be a factory rest using the back for the data and config.
Note that if you are running 4.1.x firmware you have a v1 NAS, not a v1. A v1 is limited to 2 TB disks - it won't detect the 3 TB drive size correctly, and therefore won't resync.
There's a lot of confusion here, due to some poor branding decisions Netgear made some years ago. One reason I ask about firmware version is to verify that the NAS platform is what the owner thinks it is.
