MInDev
Dec 31, 2017Aspirant
ReadyNAS NV+ v2 main fan replacement
Hello, The main system fan in my ReadyNAS NV+ v2 has started to make a loud buzzing/whine recently, so I'd like to replace it. The current (fan) unit is made by Y.S. Tech (identical models are av...
- Jan 01, 2018
I did a bit of googling on this and both fans appear to have the mounting holes at 82.5mm centres, so you should be OK
bedlam1
Jan 01, 2018Prodigy
