MInDev
Dec 31, 2017Aspirant
ReadyNAS NV+ v2 main fan replacement
Hello, The main system fan in my ReadyNAS NV+ v2 has started to make a loud buzzing/whine recently, so I'd like to replace it. The current (fan) unit is made by Y.S. Tech (identical models are av...
- Jan 01, 2018
I did a bit of googling on this and both fans appear to have the mounting holes at 82.5mm centres, so you should be OK
bedlam1
Jan 01, 2018Prodigy
MInDev
Jan 01, 2018Aspirant
Much oblged bedlam1, that's very helpful, thank you.
- MInDevJan 06, 2018Aspirant
I just wanted to add a short addendum to this which might serve as a precautionary note for others (something I've belatedly realsed in retrospect). Immediately before the fan noise began, I dismanted the unit to clear it of accumulated dust. I sprayed the whole case liberally with compressed air, including the fan - which span up to an enormously rapid rotation rate. In my ignorance I hadn't appreciated that I could inflict damage this way, but that's clearly what happened; I overburdened the fan assembly. It may well have gone on to give many more years of service otherwise.
