mattson
Jan 28, 2017Aspirant
Readynas NV+ v2 reporting Fan 1 has failed (SYS 0 rpm)
Hi There, Today my trusty RND4000v2 reported a Sys fan fail (on front view) and Fan 1 has failed (SYS 0 rpm) in the logs. I can see and feel the fan is spinning and disk temps are about nor...
FramerV
Jan 30, 2017NETGEAR Employee Retired
Hi mattson,
I would suggest that you do a back-up for now. In your case, any step might be dangerous to the ReadyNAS at this point.
Once you have a back-up, you could consider the downgrade.
FramerV
Feb 03, 2017NETGEAR Employee Retired
Hi mattson,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
