Mrhaydo
Feb 12, 2017Aspirant
ReadyNAS NV+ v2
Hmmm... My ReadyNAS is sick Hopefully i can get a steer from you good folks in the community. I have an NV+ V2 with a mixture of 2,3 and 4 TB drives. The unit is 4-5 years old. Was running li...
- Feb 12, 2017
Your best option is probably paid netgear support (ask about per-incident). If data recovery is needed it will be expensive. And you'll need a healthy disk 2.
Feb 12, 2017Guru - Experienced User
- MrhaydoFeb 12, 2017Aspirant
Much appreciated Stephen.
$49.95 USD for an incidant, i am happy to pay that. Will i need to send my array overseas do you think or is thsi something they can do remotely? What seems bizzare is the only mechanisim for engaging support is via the telephone, what year is it?
Thanks again. i may come back here and update the community on how i got on.
- StephenBFeb 12, 2017Guru - Experienced User
The support will be remote (you'll need to boot it into tech support mode). If data recovery is needed (hopefully not) then becomes a lot more expensive.
