kenlee68
Apr 28, 2020Aspirant
ReadyNAS NV+ [X-RAID]
Hi, I have an old ReadyNAS NV+ [X-RAID] and have movies files saved on it a long time ago, there are some over 4G size and I am not sure how I copied it over, I am trying to get it off to my comp...
kenlee68
I have tried to copy the file on the Netgear NAS to my Windows 10 Enterprise 64bit PC, the drives are formatted to NTFS, an error code pop up and when I looked up the code, it said to change the register on my PC so it can copy the files. But the registery can only be set to hex-decimal ffffffff and can only handle 4G file size
I tried dragging it from one mapped NAS windows to the other mapped NAS windows but same error, the other NAS is an old Synology 1010+ too but that one I can copy a file over 4G from my PC to it and copy it back down to my pc.
So not sure how I got the big files on the Netgear, just want to make a copy to the Synology.
kenlee68
Hi all,
I have worked it out, I turn on ftp and use that to transfer the files over.
Thanks
- StephenBApr 28, 2020Guru - Experienced User
That would work. My older NAS are backups, with files transfered using rsync backup jobs. That also handles large files.
Were you using file explorer before? That should also work, though it's been quite a while since I tried it.
- kenlee68Apr 28, 2020Aspirant
File explorer didn't work using \\NAS_IP\shared folder to \\Synology_IP\shared folder, I have also tried robocopy GUI and didn't work, I didn't tried the command line, perhaps that might work.
I could use the browser with ftp or the WS FTP client to do it now.
I think if the storage usage is correct on the Netgear NV+ (X-RAID (Expandable RAID), then that is a lot more compact, only used less than half the space compared to the Synology.
I don't own a Synology, but I think you are misinterpreting what you are seeing.
The files aren't compressed on the NV+. The on-disk storage for the files should be taking about the same amount of space on all file systems. If your Synology uses btrfs, there might be snapshots that account for the difference.
Generally that's not the most efficient way to do it, NAS backup jobs on one of the two NAS would work better.
What was the exact error message you saw?
