marcintalarczyk
Aug 05, 2024Aspirant
ReadyNAS NV+ [X-RAID]
Hi All I have old Netgear NAS NV+ with 4 bay. Work only 2 bay. Any one have idea why 2 others bay are unactive??
marcintalarczyk
I have 4 500GB disks loaded. It only sees 2. I swapped disks. It sees all 4, but only two slots are active. Two slots damaged, i.e. slot 3 and 4??
Aug 05, 2024Guru - Experienced User
I suggest trying the test above - note you can use any disk of 2 TB or less.
