duffa109
Sep 08, 2023Tutor
ReadyNAs NV+v2 - does Factory Reset on every boot
I acquired a ReadyNAS NV+ V2 and placed an old 1TB Windows drive into bay 4 and performed a Factory Reset to setup the disk up.. All went well but now every time the NAS is powered on it boots to Fac...
Sep 08, 2023Guru - Experienced User
duffa109 wrote:
I acquired a ReadyNAS NV+ V2 and placed an old 1TB Windows drive into bay 4 and performed a Factory Reset to setup the disk up.. All went well but now every time the NAS is powered on it boots to Factory Reset every time!?
Can somebody help me with this please?
Firmware RAIDiator 5.3.13
Do you have another disk you can try?
- duffa109Sep 09, 2023Tutor
Yes, I do have another 1TB drive and want to pair it with the one that now appears to be locked.
I did attach the disk to a PC to reformat it using Windows disk manager but kept failing with i/o error. Also tried the 'clean' option in diskpart but that also failed too.
I will try the other disk but feel I can't use the locked one to have as RAID 1.
I'll let you know.
I removed the disk and replaced with another then factory defaulted the ReadyNAS and all ok and reboots with no problems so clearly the other disk is at fault (i.e. locked).
I placed the disk back into the ReadyNAS which was disk checked while booting and no problems found.
However, when viewing volumes only the boot disk shows and not the 2nd one (I only have to disks on the ReadyNAS), bay 1 is the boot disk and bay 4 is the one that causes the boot to factory default when loading on it's own.
Any idea how to check if it has been locked and how to remove it so I can set up a RAID 1?
- StephenBSep 09, 2023Guru - Experienced User
Are you sure the disk is locked, and not simply failed?
