duffa109
Sep 08, 2023Tutor
ReadyNAs NV+v2 - does Factory Reset on every boot
I acquired a ReadyNAS NV+ V2 and placed an old 1TB Windows drive into bay 4 and performed a Factory Reset to setup the disk up.. All went well but now every time the NAS is powered on it boots to Fac...
duffa109
Sep 09, 2023Tutor
Yes, I do have another 1TB drive and want to pair it with the one that now appears to be locked.
I did attach the disk to a PC to reformat it using Windows disk manager but kept failing with i/o error. Also tried the 'clean' option in diskpart but that also failed too.
I will try the other disk but feel I can't use the locked one to have as RAID 1.
I'll let you know.
duffa109
Sep 09, 2023Tutor
I removed the disk and replaced with another then factory defaulted the ReadyNAS and all ok and reboots with no problems so clearly the other disk is at fault (i.e. locked).
I placed the disk back into the ReadyNAS which was disk checked while booting and no problems found.
However, when viewing volumes only the boot disk shows and not the 2nd one (I only have to disks on the ReadyNAS), bay 1 is the boot disk and bay 4 is the one that causes the boot to factory default when loading on it's own.
Any idea how to check if it has been locked and how to remove it so I can set up a RAID 1?
- StephenBSep 09, 2023Guru - Experienced User
Are you sure the disk is locked, and not simply failed?
- duffa109Sep 10, 2023Tutor
The disk passes the disk check test from the NAS... I would expect if there were a problem the NAS would show BAD Disk as I tried a known bad disk that fails in Windows...
Is there a way to check if it has been locked as I can't access it with Windows either..
I know disks can be unlocked according to the fix in the below link, the user mdgm-ntgr resolved the issue.
- StephenBSep 10, 2023Guru - Experienced User
You of course can try to unlock.
The linux command requires that hdparm be installed.
hdparm --security-unlock NETGEAR /dev/sdX
Substituting the real drive letter for sdX. You need to either be logged in as root, or use sudo in front of the command.
