duffa109
Sep 08, 2023Tutor
ReadyNAs NV+v2 - does Factory Reset on every boot
I acquired a ReadyNAS NV+ V2 and placed an old 1TB Windows drive into bay 4 and performed a Factory Reset to setup the disk up.. All went well but now every time the NAS is powered on it boots to Fac...
Sep 10, 2023Guru - Experienced User
Are you sure the disk is locked, and not simply failed?
duffa109
Sep 10, 2023Tutor
The disk passes the disk check test from the NAS... I would expect if there were a problem the NAS would show BAD Disk as I tried a known bad disk that fails in Windows...
Is there a way to check if it has been locked as I can't access it with Windows either..
I know disks can be unlocked according to the fix in the below link, the user mdgm-ntgr resolved the issue.
- StephenBSep 10, 2023Guru - Experienced User
You of course can try to unlock.
The linux command requires that hdparm be installed.
hdparm --security-unlock NETGEAR /dev/sdX
Substituting the real drive letter for sdX. You need to either be logged in as root, or use sudo in front of the command.
- duffa109Sep 10, 2023Tutor
Hi.
I have connected the disk in a USB docking station to a Raspberry Pi 2 and unable to mount the drive.
I used command 'sudo disk -l' and 'lsusb' and the disk does not show as a sdxx device.
It seems the disk is just unreadable in both Windows and Linux.
I'm just going to bin this disk as I don't want to waste your or my time.
Thank you for all your input.
- duffa109Sep 11, 2023Tutor
Just as a side note I used SeaTools which shows the disk as security locked!
