Dfurn21
Aug 09, 2023Aspirant
ReadyNAS NV+v2 - Windows 11 issues
Hi Guys, I'm having some issue with my readyNAS NV+ v2. I have managed to get it accessible via its webmin by setting the SMB and using firefox ReadyNAS model no: RND-4B Serial: RND4000-20...
Sandshark
Aug 10, 2023Sensei - Experienced User
Do you have anonymous access enabled on the NAS? If so, turn it off.
Have you recently changed your password? If you (possibly unintentionally) saved the NAS credentials to Windows, then you changed them, it's sending the wrong password and it usually doesn't ask you for a new one -- it just fails.
Is your user name the same in Windows as on the NAS, but not the password? That will also cause Windows to send the wrong password and, again, it usually doesn't ask for a different one, it just fails.
