Dfurn21
Aug 09, 2023Aspirant
ReadyNAS NV+v2 - Windows 11 issues
Hi Guys, I'm having some issue with my readyNAS NV+ v2. I have managed to get it accessible via its webmin by setting the SMB and using firefox ReadyNAS model no: RND-4B Serial: RND4000-20...
Dfurn21
Aug 10, 2023Aspirant
Thank you,
Its now accessible via chrome.
This is what i got from CMD as per your entries:
C:\Windows\System32>net use * /del /y
There are no entries in the list.
C:\Windows\System32>net use t: \\10.1.2.80\c /u:admin nas-admin-(my password)
System error 86 has occurred.
The specified network password is not correct.
C:\Windows\System32>net use t: \\10.1.2.80\c /u:admin (my password)
System error 67 has occurred.
The network name cannot be found.
The comment from Sandshark reg "Do you have anonymous access enabled on the NAS" has rectified the files not being accessible via file explorer, however its looks to be wiped as i cant see any of my files etc?
It also worth noting that when I try to copy and paste a file into one of the folders it does noting and when I try to drag and drop a file into one of the NAS folders and red cross circle is shown and tile isn't dragged in.
Password hasnt been updated in approx several years.
Dfurn21
apologies, I have also updated the workgroup name to match my W11 PC but this has also made no difference in CMD giving the same system error 67 message or to my file explorer issue.
- Dfurn21Aug 10, 2023Aspirant
Not sure if this is worth mentioning but under overview page, there no info in hardware/services/network/volumes.
If I install a USB stick in the front port of the NAS then that does appear as a volume.
- schumakuAug 11, 2023Guru - Experienced User
Worth repeating at this point that the Workgroup name is just for convenience, and has no security impact. Very different from a domain name ...
