falpaol_67
Jul 16, 2018Follower
Readynas NVX PSU fault and Readynas new model drives compatibility
My Readynas NVX 4 bays has died (PSU issue) and I'm planning an upgrade in order to simply insert my 4 RAIDs disks (well working) in the new unity and use it.
I've found a full compatibility with R...
Jul 16, 2018Guru - Experienced User
falpaol_67 wrote:
I've found a full compatibility with RN626X00,
Not really. With x86 OS-6 ReadyNAS, you can temporarily mount your volume so you can offload data. But you cannot simply migrate the disks - after you offload data, you complete the setup, and that will reformat the disks. OS-6 uses the BTRFS file system, so you can't simply migrate. https://kb.netgear.com/29957/ReadyNAS-Migrating-disks-from-RAIDiator-4-2-to-ReadyNAS-OS-6-x86
falpaol_67 wrote:
could you provide me some further models
Any OC 6 desktop model of RN300 series or better supports the temporary mounting feature.
For direct migration you'd need to purchase a used OS 4.2 system (pro, ultra, ultra pro). Anything you find will be at least 5 years old. You could also replace the PSU in your NVX.
