falpaol_67
Jul 16, 2018Follower
Readynas NVX PSU fault and Readynas new model drives compatibility
My Readynas NVX 4 bays has died (PSU issue) and I'm planning an upgrade in order to simply insert my 4 RAIDs disks (well working) in the new unity and use it.
I've found a full compatibility with R...
mdgm-ntgr
Jul 16, 2018NETGEAR Employee Retired
The current desktop OS6 x86 systems are RN420 series, RN520 series and RN620 series (e.g. the RN626X you mentioned).
I would recommend getting a new system rather than buying a second hand unit with no warranty and no support, even though with a new system you'd need to follow the KB article StephenB linked to above.
If you did replace the PSU in the NVX you'd have to make sure that it's wired appropriately.
