FuriousD
Jul 08, 2011Aspirant
ReadyNAS or Synology for me?
Currently have an iMac with over 10,000 photos, about 60GB of apple lossless music files which is growing and about 60GB of movies. The HDD on the iMac is 320GB. I stream the music to a Sonos ZP90, an...
mdgm-ntgr
Jul 17, 2011NETGEAR Employee Retired
An Ultra 2 with a 1TB drive and a 2TB drive would give you 1TB of space. After replacing the 1TB drive, a resync would take place and the volume would expand to 2TB.
3TB drives are supported (higher capacity drives should also be supported at some point after they are released) on the Ultra, so you can eventually move to use those.
Personally I would recommend getting an Ultra 4 or Ultra 6
