FuriousD
Jul 08, 2011Aspirant
ReadyNAS or Synology for me?
Currently have an iMac with over 10,000 photos, about 60GB of apple lossless music files which is growing and about 60GB of movies. The HDD on the iMac is 320GB. I stream the music to a Sonos ZP90, and movies to the PS3.
I want to free up space on the iMac and centrally locate the photos, music and movies so i can access from the iMac, work laptop, stream to sonos and movies PS3 without the iMac being on. Also to use Time Machine for document back up from the iMac.
I was looking a 2 x 2TB drives NAS and using RAID 1, one that can power down to save energy. Currently i have no back up of anything and once i have transfered the files to the NAS i dont want to loose them either, i know that RAID is not a back up, but the photos, music and movies will not change just be added to. I will then get an external HD to connect to the NAS for extra back up.
For Time Machine i was thinking of allowing 500GB of space leaving 1.5TB for media related stuff.
I have been looking at a number of difference NAS's but keep going round in circles. Readynas Duo, Readynas Ultra 2, Synology DS211j.
What is going to be best for me.
Thanks in advance, i have read a lot of different threads on here but like i say i keep going round in circles.
So much so that i am thinking that maybe a Ultra 2 with 2 x 1TB HD's not using RAID and backing up to an external HD might be a better idea. Is there any point of RAID for me.
Cheers
D
Cheers
D
- FuriousDAspirantHi guys,
Me again :D
Going to make a purchase just need to check something. If i wanted to add another NAS be it ReadyNAS or another product at a later date i assume i can do this no problem.
I cant afford an Ultra 4, An Ultra 2 with 2TB running RAID will be plenty for the next few years at least, however when the kids start to get their own computers Mac/PC then we might need to look at it.
For example i could add an Ultra 4 (or equivalent) then to work along side the Ultra 2?
Cheers
D - they can work along side each other as independent servers.
there is no way to 'link' them as one single combined server with combined space.
what alot of people do with 2 nas, is one be the primary and the other backup the primary (either in whole or part) - FuriousDAspirantThanks Tekno
D - dbott67Guide
FuriousD wrote: For example i could add an Ultra 4 (or equivalent) then to work along side the Ultra 2?
Absolutely. At one point or another, I've had an NV+, Pro (6-bay) and NVX all on the same network. I gave the NV+ to my dad and use the Pro for my primary storage and NVX to act as backup. At work, I've got 3 rack-mount ReadyNAS 2100s acting as primary and remote backup targets for my servers.
The benefit of going with the Ultra2 is that you can migrate the existing disks right into an Ultra4 or Ultra6, however, I might be inclined to continue using the Ultra2 as a backup when you reach that stage.
The ReadyNAS product uses industry-standard protocols, so you should be able to get it working with virtually any other device that supports those protocols (Windows devices, Apple OSX, Linux, other compliant NAS devices, etc.), but as Tekno mentioned, they're not "stackable" --- they each function as an independent network device (much like all of your computers).
-Dave - FuriousDAspirantHi all,
Thought i would give an update. My Ultra 2 was delivered at the weekend with 2 x 2TB drives. Put the drives in and let them sync which obviously took a while, went out for a bit anyway. Transfered my itunes folder across which also took a while but a quick test and the Sonos was playing.
The Ultra is much more complex than i imagined in terms of you can do so much with it. looking forward to having another play tonight and sorted my home network out.
Thanks again for all the advice and so far i am very happy with the purchase, lets hope it continues to be like this.
Cheers
D - dbott67GuideGlad everything is running smoothly. If you have any questions, just ask. 8)
Btw, in addition to trying to wrap your head around all of the built-in functionality, there are dozens of community add-ons that can allow your NAS to do some pretty cool things.
viewforum.php?f=48
