eton
May 05, 2023Luminary
ReadyNAS OS 6.10.9 now available – With almost no info
ReadyNAS OS 6.10.9 now available! https://kb.netgear.com/000065653/ReadyNAS-OS-Software-Version-6-10-9 But there is almost no release information. What is new? There is no option to filter ...
eton
Jun 26, 2023Luminary
Netgear is still not pushing this update to clients. In other words you can still not get this update via the web GUI firmware update method.
The time from publishing the update to it being available via web GUI has been exceptionally long.
This is just another circumstantial evidence that Netgear just don't care about ReadyNAS anymore.
eton
Aug 18, 2023Luminary
Netgear still don not push update version 6.10.9 to clients.
Have you manually installed it?
Did you notice any changes?
And still NO release information: https://kb.netgear.com/000065653/ReadyNAS-OS-Software-Version-6-10-9
- StephenBAug 18, 2023Guru - Experienced User
I installed it some time ago. The only visible changes are that the Netgear Repo remains broken in 6.10.8, but not in 6.10.9. That's not inherent to the update though, they could (and should) just fix the broken repo.
True. Although it does point to netgear.com/about/security for security info, there is nothing there for 6.10.9 (just one fix that was in 6.10.8).
And if you look inside the zip, you'll find the release notes for 6.10.8.
So no way to know the impact of the vulnerabilities in 6.10.8 that they say they fixed.
- etonAug 18, 2023Luminary
Thanks for your reply StephenB
Bundling 6.10.9 with release information from 6.10.8 i yet another blunder.
Yes, it would be much better if Netgear fixed their repo instead of forcing all clients to use another repo.
- timbck2Aug 18, 2023TutorI ended up replacing my Netgear with a Synology DS220+. Is anyone interested in buying a used Netgear RN214? I’ll even throw in the drives that are installed in it - it has four 4.0TB WD Red (NAS) drives (WD40EFRX). Drop me an email with an offer if you’re interested: [email protected].
