GasNas
Jan 20, 2016Aspirant
readynas os 6.2 Device Communication Error
I'm already out of my depth here. The ReadyNAS has been discovered, but I can't get past this - Readycloud temporarily lost connection with your storage system. I've turned everything off and on ...
- Jan 22, 2016
Go to System > Network and check the settings for your adapter. If it is set to static make sure the DNS server addresses have been specified. You could try adding an additional one e.g. 8.8.8.8
GasNas
Jan 22, 2016Aspirant
That's all news to me.
Could you please point me in the direction of where I can find how to do that?
Many thanks.
mdgm-ntgr
Jan 22, 2016NETGEAR Employee Retired
- GasNasJan 22, 2016Aspirant
Is that on the page with Links / Routes?
If so, I can see IP address etc but I don't know how to determine what's static etc.
The manual doesn't seem to mention any of this...
- StephenBJan 22, 2016Guru - Experienced User
Yes. Click on the settings wheel next to the adapter image. Then click IPv4. If "configure" says "using dhcp" then you are using an automatic address (which is the default, and almost certainly what you are using).
There is a big "+" next to DNS Servers - you can click that and add 8.8.8.8.
8.8.8.8 is a DNS server run by Google.
- GasNasJan 23, 2016Aspirant
Thanks for such clear instruction.
I've done that and when I go back to readycloud, on the home and manage pages, it says i have no registered / shared devices.
On the ReadyCLOUD Discover page, when I click Manage (where it used to say set up) which takes me to the NetGEAR ReadyNAS Admin Page > System > Device > Overview where it looks fine to me, and I can see the folders on the Shares tab.
In My NetGEAR / My Products it looks all ok.
How do i tie it together with the readyCLOUD Home which is how it looks to appear in the youtube video demo?
- mdgm-ntgrJan 23, 2016NETGEAR Employee Retired
What do you see on the CLOUD tab of the local web admin page?
- StephenBJan 23, 2016Guru - Experienced User
Did you enable ReadyCloud on the NAS?
great i'm well and truly on board now.
Thanks for your patience and help!
Phil
- BrianL2Jan 23, 2016NETGEAR Employee Retired
Hi GasNas,
Thanks for your feedback. The thread is now closed and we hope that you will continue to contribute to the community by asking questions, giving suggestions and sharing ideas.
Kind regards,
BrianL
NETGEAR Community Team
