Anton_'s avatar
Anton_
Tutor
Sep 04, 2020
ReadyNAS OS 6, Remote admin config
I did a firmware update from OS4 to OS6 Successfully.
My question is if i can somehow configure a user or such to let my friend login as admin or either a normal user with admin permissions to help me setup my NAS. I hope you understand my kinda question.
I understand that open up the NAS to worldwide would not be good thing so i thought maybe i can use port forwarding in my router to just allow incomming connections from his WAN-ip ?
Have i missunderstood or are there a better way? Maybe there is a Netgear addon for this?
  • StephenB's avatar
    If you set up ReadyCloud on the NAS, then your friend could use that. You'd need to give him the NAS admin credentials though
    Anton_ wrote:
     i thought maybe i can use port forwarding in my router to just allow incoming connections from his WAN-ip ?
    Routers I've owned don't let you filter inbound connections that way.
    • Sandshark's avatar
      Sandshark
      Sensei
      A VPN is what you want here.  ReadyCloud is a VPN and then some.  Many routers have VPN capability built in.  I personally use ZeroTier to administer my backup NAS at my brother's house 3 states away, though the ReadyNAS-specific app for it is getting quite old.
      • Anton_'s avatar
        Anton_
        Tutor
        Aha.. okey!
        Cant use ReadyCloud it seems. The device needs to be registered it says when i try to upgrade my mynetgear account.
        Since the device is bought used previous owner has allready registered it and i cant register. So ReadyCloud cant be used.
        So i need to look into some other services.
        ZeroTier, is it free to use?
ProSupport for Business
