funglenn
Dec 10, 2019Luminary
ReadyNAS OS forks 6.9.5 vs 6.10
So my understanding is that 6.9.5 would continue to receive fixes vs new capabilities via hotfixes. New capabilities would be introduced in 6.10 and subsequent versions. However I see fixes intr...
Dec 10, 2019Guru - Experienced User
funglenn wrote:
... I see fixes introduced into 6.10--will those be covered in a 6.9.5 hotfix 2? or is there not a lot of priority placed toward those to stayed in 6.9.5? 6.9.5 is quite stable!
At some point the long term stable (LTS) release will shift upwards to 6.10.x. So Netgear might do that instead of releasing more hot fixes to 6.9.5.
Also, the LTS release is currently 6.9.6, not 6.9.5. https://kb.netgear.com/000061331/ReadyNAS-OS-6-Software-Version-6-9-6-Long-term-support-version-of-6-10-2
- SandsharkDec 10, 2019Sensei
StephenB wrote:Also, the LTS release is currently 6.9.6, not 6.9.5. https://kb.netgear.com/000061331/ReadyNAS-OS-6-Software-Version-6-9-6-Long-term-support-version-of-6-10-2
Though checking for an update on a 6.9.5 unit with the LTS option selected will not show you this update is available.
- funglennJan 07, 2020Luminary
although frankly to have many LTS versions becomes confusing, i get that. However even the title of this link:https://kb.netgear.com/000061331/ReadyNAS-OS-6-Software-Version-6-9-6-Long-term-support-version-of-6-10-2
ReadyNAS OS 6 Software Version 6.9.6 - Long-term support version of 6.10.2
is very confusing as you cannot download 6.9.6, just 6.10.2. That begs to ask the question what about 6.9.6 and others like mine. I feel like I am being given a false sense of security on what I will receive if anything for those of us still on 9.6.5 as LTS.
- SandsharkJan 07, 2020Sensei
The download link is on the page linked above, though you have to manually install it. It's just two bug fixes:
Bug Fixes:
- Fixed Microsoft OneDrive authentication issue
- Updated Gmail notifications to follow Google's security requirements
If neither of them affects you, you needn't bother (I haven't).
