crane10970
Feb 17, 2025Aspirant
ReadyNAS OS Where is version info stored? 6.10.9 x64
Hi, this is topic following question in large topic (https://community.netgear.com/t5/New-ReadyNAS-Users-General/ReadyNAS-312-swapping-HDD-for-SSD-filesystems-data-transfer/m-p/2430732/emcs_t/S2h8ZW...
Feb 17, 2025Guru - Experienced User
Just turning off update notifications will prevent the NAS from advertising 6.10.10 when you log into the admin web ui.
- Go to System->Settings
- Expand "Update" if needed.
- Uncheck "Notifications for updates" in the second column of the update section.
- crane10970Feb 17, 2025Aspirant
I am awared there is such an option, but i would like to know, where is version info store.. if file, or mysql database. Running MySQL along with PHPMyAdmin gave me access probably to NAS sql database in the very same moment and files i can search or search content.. would you know or could specify pls, how ReadyNAS OS version info is stored?
How the OS itself handles version and version info in webadmin page? .. meanwhile im going to look on webadmin files content. 🙂
- StephenBFeb 17, 2025Guru - Experienced User
crane10970 wrote:
I am awared there is such an option, but i would like to know, where is version info store.. 🙂
I've never tried to hack the version info, so I do not know the implications of attempting it.
Also, I see no need to hack it, since there is a simple way to block an inadvertant update.
- SandsharkFeb 18, 2025Sensei
What Debian components are missing from 6.10.10? I've never gone to it except on a sandbox system.
