ArchPrime's avatar
Apr 22, 2023
ReadyNAS OS6.10.8 - how to install docker
Hi it appears that installation  of the app 'Docker CE CLI' always fails, even though it is listed as available under OS 6.10.8, with no warning that it is no longer supported.   What is the ...
  • StephenB's avatar
    Apr 23, 2023
    Like all third-party apps, it never was supported by Netgear.  It was submitted to the app store by a ReadyNAS user ( Mhynlo) who hasn't been active here for about 5 years.
    One factor here is Debian's recent end of support for Jessie (the version of Linux that the ReadyNAS uses). Installs that need new debian libraries are failing because the Jessie depository was moved to an archive by the Debian folks. There is some info on that here:
    Though there could be other issues with the Docker app.
ProSupport for Business
