ArchPrime
Apr 23, 2023Guide
ReadyNAS OS6.10.8 - how to install docker
Hi it appears that installation of the app 'Docker CE CLI' always fails, even though it is listed as available under OS 6.10.8, with no warning that it is no longer supported. What is the ...
- Apr 23, 2023
Like all third-party apps, it never was supported by Netgear. It was submitted to the app store by a ReadyNAS user ( Mhynlo) who hasn't been active here for about 5 years.
One factor here is Debian's recent end of support for Jessie (the version of Linux that the ReadyNAS uses). Installs that need new debian libraries are failing because the Jessie depository was moved to an archive by the Debian folks. There is some info on that here:
Though there could be other issues with the Docker app.
eton
Apr 23, 2023Luminary
An updated version of Docker CE CLI (19.03.9) for RN OS 6:
https://github.com/jdnowak/readynas_docker
Info
https://docs.docker.com/engine/release-notes/19.03/#19039
itachi2
Apr 24, 2023Tutor
That's awesome - I think with some reading and trial and error I was able to get Docker 18.06.3-ce, build d7080c1 installed which was the last version with Debian 8 support. But it'll be really nice to move up to a newer version.
