gggplaya
Apr 15, 2016Aspirant
Readynas OS6 http default web share page???
Hi, i have an original Readynas Duo version 1, it's been working flawlessly for years and still works great for what i need. I use it to backup files, and keep my blu ray rips onto, as well as famil...
Apr 15, 2016Guru - Experienced User
No. Normal users can access a specific share with HTTP using https://nasname/sharename From that page they can download, but not delete/rename/move.
However, the admin UI does include this functionality, integrated into the shares screen.
gggplaya
Yea, i don't need to rename or move, just download like it does now.
Currently i just give someone my easy-to-remember-domain.com and their username and default password. Then let them change the password to one they typically use without me seeing it. Then they can just type the domain and have acess to all the shares.
Does ready cloud offer this type of functionality??? I can probably point my domain to a readycloud address.
- mdgm-ntgrApr 16, 2016NETGEAR Employee Retired
With ReadyCLOUD they would just need to go to readycloud.netgear.com in their web browser or download an app onto their PC/Mac/iOS/Android device.
Also note in 6.5.0 (coming soon) we will be changing to using SSO for ReadyCLOUD accounts so it may be easiest to get your NAS, update it to 6.5.0 when that comes out and then setup ReadyCLOUD rather than get your users to sign up to ReadyCLOUD and then need to migrate to a SSO account.- gggplayaApr 17, 2016Aspirant
i ended up buying a different brand of NAS. I really don't want people to have to sign up for anything or go out of their way to log into my nas. All are friends and family, some are very old, it's just easiest to set everything up for them and hand them a username and password.
- mdgm-ntgrApr 17, 2016NETGEAR Employee Retired
Disappointed to hear that. There are alternatives to ReadyCLOUD. ReadyCLOUD is an optional feature and there is no requirement to use that. I just explained it as you asked about it and I thought you may find it useful.
You could have used local admin users and used what StephenB mentioned in his post.
Btw if the user has registered a NETGEAR product or signed up to this community they would already have a SSO account. We are changing to using SSO accounts for ReadyCLOUD in 6.5.0 to reduce the number of accounts users need to use the functionality available in NETGEAR products.
With ReadyCLOUD you can share links to files/folders and users don't need an account to download files/folders you link to.We do have a Virtual Machine of OS6 that can be played with e.g. using VirtualBox (free software) and there is an online demo available at rndemo.netgear.com. You can test a bit more using the Virtual Machine than with the online demo.
