Rootax
Jun 17, 2016Luminary
Readynas OS6, SSD, and TRIM
Hello :) I read that Readynas OS6 support SSDs, but I've hard time finding if the TRIM command is supported. And if so, does this work on a raid array ? For the record I've an "old" Readynas ...
- Jun 17, 2016
We don't do TRIM currently. You can enable it manually on your volume by changing your /etc/fstab file from something like this
LABEL=12345678:data /data btrfs defaults 0 0
to this
LABEL=12345678:data /data btrfs defaults,discard 0 0
Jun 17, 2016Guru - Experienced User
Hopefully Netgear will answer on TRIM. They might think that the garbage collection built into modern SSDs is good enough.
It would be interesting to hear what happens to the temps/power use. You should also see performance gains on random I/O (since you are certainly not maxing your gigabit ethernet on those).
You will need 2.5 to 3.5 inch tray adapters, since almost all SSDs are 2.5"
- RootaxJun 17, 2016Luminary
Oh yeah, when talking about the speed, I was talking about big files transferts (which is mostly my usage).
For the adapter, a guy used 2'5 drives without them, as you can see there : http://www.magnuswedberg.com/index.php?doc=2_5_inch_disks_in_a_Netgear_Readynas
Maybe garbage collection is enough, on a 24/24 running system I can buy that (since the mechanism have time to do it), but an official response would be cool :)
- StephenBJun 17, 2016Guru - Experienced User
I suggest the adapter anyway, it will ensure the connectors are precisely aligned and keep the drive from slipping. They are inexpensive - ~ $5 in the US.
I agree that a response on TRIM would be good, there are people who recommend it despite GC. I don't know enough to have an informed opinion on that.
About the adapter, the guy said "Also, most docks and mechanical adapters won't care about the positioning of the SATA connectors, which is crucial in this case." So, I'm not sure it's will work. Does netgear provide such adapter ? Or you can use any one in the market ?
