brb1800
Jul 14, 2015Aspirant
ReadyNAS Pro - Replace CPU Fan
The 80mm CPU fan on my ReadyNAS Pro Business NAS is starting to go. This is an early model that arrived with the CPU three pin header connected to the daughter board, as opposed to the main board. ...
brb1800
Note the CPU fan wire is attached to the daughter board header toward the rear of the NAS. The rear 120mm case fan attaches to the other header on the daughter board.
After taking the photo the case was vacuumed out the rear 120mm case fan was put back in the case.
The Seasonic PSU was also replaced. This original PSU is in the photo.
tret
Aug 10, 2015Aspirant
Can you go into a little detail about your PSU swap? What PSU did you replace it with? Why? Quieter by chance?
- gregb_proSep 01, 2015Aspirant
Yes, I am also interested in power supply options for a ReadyNAS Pro 6 / Business Edition.
Thanks, gregb
- netracerSep 24, 2015Apprentice
I happened to just do a power supply swap. The stock unit is a Seasonic 300W. I picked one up on Newegg - Seasonic SS-300SFD 300W (Link) BUT - it will require modification. You will need to buy a 4" 24-pin ATX power extension (e-bay) and you will need to swap the hard drive power connectors.
The original has (3) single 4-pin molex connectors for the drive board, a lengthy braided 24 pin connector and a 4-pin aux connector.
The new unit is more 'standard' and has (2) double 4-pin molex leads with a 4-pin diskette power connector (really?), one double SATA lead, the 4-pin aux connector lead and a 24pin ATX connector lead that is too short.
DO THIS UNPLUGGED PLEASE!!!!!
I removed the old molex connectors and reused, necessary for the SATA cable but I did it on all of them to be neater as the originals have the cables at a 90° offset to the connector (I want to leave room for a 38mm fan someday).
Put the empty molex connectors into the slots on the drive board and cable by cable (maintaining color order) cut to size (route cables first allowing room for fan) and press into the appropriate molex slot. There are two black cables that doesn't matter if they are flipped. Put the cap back on. For each set of leads you want to be sure there is only one molex connected to the drive logic board. The orange signal cable on the sata lead i just cut off and capped.
I highly advise against using the replacement power supply as is and using both molex connectors on one lead. This works in a PC where there is a single drive on each molex, but in this chassis there are 3 power connectors supporting 6 drives, so each cable lead is already carrying a two drive electic load. If you use two connectors off one lead you will effectively have 4 drives on one leg of the PS. It's possible the PS and cable can handle it, but I didn't crunch the numbers and it was easy enough to mod the connector.
Since it's the same unit, it's the same noise. I was unable to find another PS that fit the bill. Space is pretty sparse and there is a special mounting offset as well, so this is probably your best bet. Other than the simple cable mods it was pretty much plug and play.
- gregb_proSep 24, 2015Aspirant
Question regarding image of SeaSonic SS-300SFD power supply on NewEgg (link above): The NewEgg image shows the exhaust fan and AC power connector and AC switch are on different sides of the power supply. The back of the ReadyNAS Pro has power supply fan, AC power connector and AC switch all on the back panel of the ReadyNAS Pro. Is there a short AC cable within the ReadyNAS Pro?
Thanks, gregb
