n_damian
Oct 31, 2016Aspirant
Readynas Pro 2 max memory
What is max memory (ddr3) size which i can install with one slot (rndp2000)?
n_damian
Nov 01, 2016Aspirant
Yes, i'm using OS 6 on RNDP2000.
RAM is cheap so I want to install 4GB. I know that 2GB will work, but what about 4 GB?
JennC
Nov 02, 2016NETGEAR Employee Retired
Hello n_damian,
From what I've heard, users have used 2GB, I havent heard of 4GB.
- StephenBNov 02, 2016Guru - Experienced User
I think the ceiling is 2 GB per slot (Intel Atom chipset limitation).
- StephenBNov 07, 2016Guru - Experienced User
To be more clear, the Pro-2 only has one slot. So if I'm right on the intel atom constraint, the memory is limited to 2 GB.
- dsinghNov 07, 2016Aspirant
I don't think that it is a constraint of the chipset. Could be a limitation imposed by the firmware. This limitation might have been relaxed in OS6 - something that I have not tried yet.
