n_damian
Oct 31, 2016Aspirant
Readynas Pro 2 max memory
What is max memory (ddr3) size which i can install with one slot (rndp2000)?
dsingh
Nov 07, 2016Aspirant
Hi has anybody tried the following on Readynas Pro2 running OS6? Do you think that it will work?
https://ptarmiganlabs.wordpress.com/2013/08/16/add-more-ram-memory-to-readynas-rn312/
The following looks promising if 4GB works on the Pro2
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231341
dsingh
The following look promising if 4GB works on the Pro2
