n_damian
Oct 31, 2016Aspirant
Readynas Pro 2 max memory
What is max memory (ddr3) size which i can install with one slot (rndp2000)?
Nov 07, 2016Guru - Experienced User
dsingh wrote:
I don't think that it is a constraint of the chipset.
There is an old post that claims it is. In any event, I did search the forums, and I can't find anyone who has gotten more than 2 GB working on the pro-2 or ultra-2. You can get more on the larger units (I have 2x4GB working on my pro-6).
dsingh
Nov 07, 2016Aspirant
Here is the spec from Intel clearly stating that the processor supports 4GB of RAM ... http://ark.intel.com/products/49490/Intel-Atom-Processor-D525-1M-Cache-1_80-GHz
- StephenBNov 07, 2016Guru - Experienced User
It will support 2x2GB. But there's only one slot in the pro-2.
