minikN
Apr 26, 2016Aspirant
ReadyNAS Pro 4: Setting up MySQL properly.
Hello, I've been running into some troubles getting MySQL to run properly on my ReadyNAS Pro 4. But before I start explaining, I'd like to mention that I did search this and other forums for poss...
mdgm-ntgr
Apr 27, 2016NETGEAR Employee Retired
You could install the MySQLOn add-on to enable MySQL.
Your NAS won't be getting any more firmware updates, so if new security issues come up having ports forwarded to it on the web probably isn't a good idea.
You can run OS6 on your ReadyNAS which is continuing to get firmware updates but that's not supported.
- minikNApr 28, 2016Aspirant
I'm confused, can, or can't I run OS6 on my NAS? If I can, could you point to a tutorial or something like that? THanks.
