JJJCR
May 30, 2017Aspirant
ReadyNAS Pro 4 upgrade to 6.0
Hello guys, I have a ReadyNAS Pro 4 (Firmware 4.2.30), How to apply the SAMBA fix? I tried download the 6.7.0 but it says it's not valid architecture. Any help is greatly appreciated. Thanks in a...
- May 30, 2017
You can either install RAIDiator-x86-4.2.31 (which has fixes for Samba CVE-2017-7494) or backup your data and then follow the guide here OS6 now works on x86 Legacy WARNING: NO NTGR SUPPORT! to put OS6 on. You'd want to put 6.7.4 on to get the fix for the same CVE on OS6.
mdgm-ntgr
May 30, 2017NETGEAR Employee Retired
- JJJCRMay 30, 2017Aspirant
Thank you for your quick update, I think I will just for 4.2.31.
Any ideas whether 4.2.31 supports SMB 2?
Thanks again.
