NightHawk357
Oct 06, 2023Follower
ReadyNAS Pro 4
Model: ReadyNAS Pro 4
Status: Healthy
Firmware: 4.2.31
Hi all,
I just factory reset my Ready NAS and installed new drives in there. 2TB x 4.
When I try and login into the UI, I can only get to the shares (there are no shares in there yet) but not the admin screen.
Logging into the https://<myinternalIP>/admin gives me this:
This site can’t provide a secure connection
10.0.0.228 uses an unsupported protocol.
ERR_SSL_VERSION_OR_CIPHER_MISMATCH
Any help will be greatly appreciated.
Thanks
1 Reply
ERR_SSL_VERSION_OR_CIPHER_MISMATCHSee this thread for an extensive discussion:
To save you the trouble of wading through all of it:
Regaining access now can be done in a couple of ways.
- If you are running Windows, you can use either Internet Explorer, or use Edge in IE mode.
- You can also regain access with FireFox. Set security.tls.version.min to 1 (browse to about:config and search for the setting).
Once in, you again have two options.
- Install this add-on (courtesy of WhoCares_ ) : https://github.com/rdynsxtrs/rn4bin/blob/main/apache2/x86/Apache2_2.2.34-x86-0.2.0.bin
- Convert your Pro 4 to run OS-6.
Conversion to OS-6 is IMO the better path, as it also gives you SMB 3 support and other features. You would need to increase the NAS ram to 2 GB first - which is inexpensive and easy to do.
