jonjon79
Feb 14, 2025Aspirant
ReadyNAS Pro 6 - issue w/ TLS 1
product - ReadyNAS Pro 6 not updated yet. I've read other posts & have tried installing & using TLS 1.0 browser (couple older Firefox, currently on 43.0.1), also tried 94.0.2. still unable to get the...
jonjon79
after taking +/- 5 minutes or more to finally time out when trying to reach/load the page, the error says:
Secure Connection Failed.
the connection to 192.168.1.110 was interrupted while the page was loading.
The page you are trying to view cannot be shown because the authenticity of the received data could not be verified.
Sandshark
Feb 14, 2025Sensei
That sounds like a different problem. Are you running any antivirus/firewall software?
- StephenBFeb 15, 2025Guru - Experienced User
What status is RAIDar giving you?
- jonjon79Feb 16, 2025Aspirant
yes. I use Avast free AV on my Windows management laptop; and have the NAS connected to the integrated/embedded switch on my Fortinet firewall.
as far as I remember, no changes to either one since I last connected to the frontview page.
today, as I return to resume access efforts, my Avast AV wanted to update its engine & reboot. so I did. and then, following reboot, when I launched Firefox to reconnect to the ReadyNAS, I get the warning about the cert on the NAS (I'm thinking 'ok... is it going to work this time?') I allow the cert, get the login for the NAS, and then voila! I'm in!
and all I know that I did was update the AV! I made no other changes!
so now that I'm in, how do I update the NAS software to allow more recent versions of TLS & what other updates do you guys suggest? I'll put that out there while I'm digging out my USB drive to run backups on my NAS volumes.
thanks for humoring me & for all your suggestions!
- StephenBFeb 16, 2025Guru - Experienced User
jonjon79 wrote:so now that I'm in, how do I update the NAS software to allow more recent versions of TLS
One option is to convert your Pro 6 to run OS-6. That will require a factory reset, so you'd have to restore all the data from backup. Among other things, it would both update TLS and give you support for SMB 3.1. If you want more details on that, just post back and ask.
If you choose to stay with 4.2.31 firmware, you can add TLS 1.2 support by installing this add-on:
You can also make a modification to the NAS so that you can reach the admin web page with unencrypted TLS. The mod is in post 1 of this thread:
- SandsharkFeb 17, 2025Sensei
Glad to here it. Those AV updates can sneak in. At least it seems Avast recognizes folks may use old devices on their home network and made bypassing it easy. Norton 360 recently added a similar block, and bypassing it was not so simple -- even diagnosing it wasn't straightforward.
