jolo2
Apr 26, 2019Star
Readynas Pro 6 (OS 6) Fan Control with Noctua System Fan stops
I was given a ReadyNas Pro 6 and upgraded it to OS 6 (latest firmware). I soon replaced the Crown system fan with a Noctua NF-A12x25FLX 3-pin, to get efficient and relatively quiet cooling. The Noc...
- May 12, 2019
This thread also mentions the fan speed override: https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/OS-6-5-2-still-causes-fan-issues-on-the-PRO-6-like-OS-6-5-1-but/m-p/1138003#M115451
Let us know if this works...
Equinox1
Apr 27, 2019Guide
If I remember correctly, the noctua fans need something done to the cables to work
jolo2
Apr 27, 2019Star
Thanks. I'm aware of discussion about the PSU fan wiring and also about the CPU fan needing to be a four pin, but I *thought* the Crown system fan is a 3-pin and so is this Noctua and I thought that this means they would be a standard connection and interchangeable? Can we confirm/deny whether the Crown/Noctua are interchangeable?
The strange thing here is that the system runs just fine, but - inexplicably - either just after boot, or a few hours (or days) after boot, the fan will stop. It seems like something in software must be changing and - once changed - only a reboot will fix it.
