dd-walker
Feb 06, 2022Tutor
Parental Control stopped working
I have Parent Control subscription for about a month. It's been working fine. But today it stopped working. It doesn't show usage History and doesn't limit the usage.
The firmware version is 2.7.3.22.
What shall I do? Thanks.
(For some reason all the other related topics have been marked as closed)
Netgear Support finally resolved the issue I had with SPC not working following the force migration in January 2022. Basically, it would work for a few hours and then stop applying rules, logging history, etc. It was resolved end of October.
The problem was caused by Circle settings not allowing Netgear SPC to work. Level 3 support recreated by setup in their lab and built a script that deleted all trace of Circle.
After running this script into the router, I did factory reset and reinstalled the app. The profiles weren’t lost and SPC has been working for 2 weeks non stop now.
So if you are a previous Circle user on Orbi and could never make SPC work, they have a solution. Just need to point them to Level 3 script they have built. (PM me for my case number)
Thank you to Bernard for Level 2 who finally got this resolved.
Have you tried a simple reboot?
Yes, power-cycled many times.
What device(s) have you installed Orbi app and Circle on? Try a different device to compare results?
I'm using Comcast (business) Internet. The modem model is Cisco DPC3008.
I installed the Orbi app on my android phone.
I haven't tried factory reset.
I called tech support, and was told to do a reset. Afterwards, parental control works again.
- GENEXXAAspirantI am having this issue too. And there is no update for the router (RAX50) either.
Can someone send me the file?
