wcasanov
Jun 12, 2024Aspirant
ReadyNAS Pro 6 (RNDP6000) stuck at READYNAS screen after power failure.
I have a ReadyNAS Pro 6 (RNDP6000) that failed to recover after a power failure. This firmware on the device was upgraded to OS6, currently running 6.10.10 when it died. I have replaced the power sup...
wcasanov
Tried booting without disks, no luck. Network lights have now gone out, so it doesn't appear to initialize the network card anymore.
Jun 13, 2024Guru - Experienced User
Not a good sign.
You could try an OS reinstall, but I don't think it will resolve anything.
If you do try it, you use the OS-4 reinstall process, but substitute your OS-6 firmware.
- wcasanovJun 13, 2024Aspirant
I am would like to try a USB recovery using the 4.2 recovery tool. Unfortunately, the only firmware it seems to recognize is the last 4.2.31 firmware. I have all the firmwares that were ever put on the system including the R4toR6_.6.9.5.bin file, but the recovery tool does not load it. Any idea what I am doing wrong?
- SandsharkJun 14, 2024Sensei
The file name of the OS6 file has to have the same structure as that of the 4.2.31 file. Try naming it RAIDiator-x86-6.9.5 (or whatever version you're installing).
- StephenBJun 14, 2024Guru - Experienced User
Note you don't want the .img file extension. If you are hiding extensions in windows, then enable viewing them, just ot make sure you've removed it.
