wcasanov
Jun 12, 2024Aspirant
ReadyNAS Pro 6 (RNDP6000) stuck at READYNAS screen after power failure.
I have a ReadyNAS Pro 6 (RNDP6000) that failed to recover after a power failure. This firmware on the device was upgraded to OS6, currently running 6.10.10 when it died. I have replaced the power sup...
wcasanov
Jun 13, 2024Aspirant
I am would like to try a USB recovery using the 4.2 recovery tool. Unfortunately, the only firmware it seems to recognize is the last 4.2.31 firmware. I have all the firmwares that were ever put on the system including the R4toR6_.6.9.5.bin file, but the recovery tool does not load it. Any idea what I am doing wrong?
Sandshark
Jun 14, 2024Sensei
The file name of the OS6 file has to have the same structure as that of the 4.2.31 file. Try naming it RAIDiator-x86-6.9.5 (or whatever version you're installing).
- StephenBJun 14, 2024Guru - Experienced User
Note you don't want the .img file extension. If you are hiding extensions in windows, then enable viewing them, just ot make sure you've removed it.
