Lateralleap
Apr 21, 2018Aspirant
ReadyNAS Pro 6 showing system over temperature
Unit is suddenly showing system temperature over 65 C. The system fan starts around 1500 RPM, briefly went up to around 2000 RPM and then went down to around 900 even though the temperature is climbi...
mdgm-ntgr
Apr 21, 2018NETGEAR Employee Retired
Which firmware are you running?
Is there a large build up of dust? You would presumably have had this system quite a long time now.
Lateralleap
Apr 22, 2018Aspirant
Thanks for your reply
Firmware: RAIDiator 4.2.31
I have cleaned the dust out and that does seem to have helped. It's not sitting with System temperature at 58C and CPU at 34C. I have also recalibrated the fan (not sure what that does!?) after cleaning. Ambient temperature is around 22C
Does that sound healthy?
Previously it was rising to 68C
Thanks
- LateralleapApr 22, 2018Aspirant
Sorry, that should have read: "It's NOW sitting..."
- StephenBApr 22, 2018Guru - Experienced User
My pro-6 shows a CPU temp of 20C (and disk temps of 20-22C). The system temp is reported as 52C. My ambient temp is lower than yours (the system is in my basement) - probably about 18C?
Also the disks can make a big difference - the WD30EFRX that I have in the NAS run quite cool.
Many thanks, that's very helpful
