steveoelliott
Sep 10, 2012Luminary
ReadyNAS Pro 6 Temperature
Hi all,
I am concerned that my NAS may be running hotter than it should (ideally).
System temp is around 57 degree and CPU 24.5 degreee (celsius). Hard drives are 40 - 44 c.
Fan System < 893 rpm
Fan CPU 2083 rpm
Can others share theirs for me?
Thanks...
Fan CPU 2083 rpm
Thanks...
- StephenBGuru - Experienced UserFan SYS 953 RPM
Fan CPU 2163 RPM
System Temp is 58 C. CPU is 27.5 C. Drives range from 35-43 C. - vandermerweMasterUltra 6 +
Sys 55
CPU 22.5. I have always thought that these are the wrong way round, CPU cannot possibly be that cool!
Sys fan 932
CPU fan 2250
Disks 32-36 - onimodAspirantFan SYS 1308 RPM
Fan CPU 1534 RPM
Temp SYS 58 C / 136 F [Normal 0-65 C / 32-149 F]
Temp CPU 28 C / 82 F [Normal 0-60 C / 32-140 F]
Dives (6) 40-42 - evan2NETGEAR ExpertRAIDiator 4.2.22 fix the issue, it will be released these days.
- vandermerweMasterWhat issue has been fixed - the CPU / system labels?
I asked this question a while ago:
viewtopic.php?f=24&t=52630 - evan2NETGEAR ExpertFix CPU temperature issue.
- steveoelliottLuminaryWell looking at these values, looks like mine is normal but high 50's is towards the high end of the temperature scale.
- vandermerweMaster4.2.22 seems to be the same. I checked temperatures before updating, then after, almost identical. Range for CPU 0-85c
What has been fixed? - chirpaLuminaryEvan, more detail on what was fixed? Your message was not clear on what issue was addressed.
- evan2NETGEAR ExpertFix CPU temperature issue when system power on.
