steveoelliott
Sep 10, 2012Luminary
ReadyNAS Pro 6 Temperature
Hi all, I am concerned that my NAS may be running hotter than it should (ideally). System temp is around 57 degree and CPU 24.5 degreee (celsius). Hard drives are 40 - 44 c. Fan System < 893 ...
beisser1
Oct 03, 2012Tutor
OLBJAN wrote: I'm on 4.2.22 and labels are still backwards. Either that or the CPU is really 30°C colder than everything surrounding it.
-Jan
the CPU really IS running cooler than everything else since its the only thing receiving active cooling. everything else just gets the little airflow from the chassis fan.
