steveoelliott
Sep 10, 2012Luminary
ReadyNAS Pro 6 Temperature
Hi all, I am concerned that my NAS may be running hotter than it should (ideally). System temp is around 57 degree and CPU 24.5 degreee (celsius). Hard drives are 40 - 44 c. Fan System < 893 ...
vandermerwe
Oct 03, 2012Master
Why does the "system" temperature get so high so quickly then, it reaches mid 50s celcius almost immediately after booting from cold, and the "CPU" temp seems to vary according to environmental temperature.
Also there are postings of temperatures from other readynas units that indicate high cpu temperatures which is what I would expect, for example:
viewtopic.php?f=24&t=66947
Now... surely the labels are reversed?
