steveoelliott
Sep 10, 2012Luminary
ReadyNAS Pro 6 Temperature
Hi all, I am concerned that my NAS may be running hotter than it should (ideally). System temp is around 57 degree and CPU 24.5 degreee (celsius). Hard drives are 40 - 44 c. Fan System < 893 ...
bajorgensen
Oct 07, 2012Aspirant
I can confirm the permanent 50 degrees on the Ultra 6 with .22 as well.
Even thought the atom cpu has a passive heat sink, the fan blows pretty well over the cpu.
The case is pretty well designed. I've replaces the fan with a more quiet and effective on, and disabled the PSU fan.
Very quiet and no problems!
