steveoelliott
Sep 10, 2012Luminary
ReadyNAS Pro 6 Temperature
Hi all, I am concerned that my NAS may be running hotter than it should (ideally). System temp is around 57 degree and CPU 24.5 degreee (celsius). Hard drives are 40 - 44 c. Fan System < 893 ...
mdgm-ntgr
Oct 07, 2012NETGEAR Employee Retired
bajorgensen that would of course have voided your warranty. A replacement fan might not cool the system properly leading to higher temperatures than would otherwise be the case. Now so long as the temperatures don't get too hot you'd hopefully be O.K. but NetGear does optimise fan control etc. for the fans they use and other fans may not do an adequate job.
I don't think disabling the PSU fan was a good idea either. Any fans used would be used with good reason. If it isn't properly cooled the PSU could overheat.
