steveoelliott
Sep 10, 2012Luminary
ReadyNAS Pro 6 Temperature
Hi all, I am concerned that my NAS may be running hotter than it should (ideally). System temp is around 57 degree and CPU 24.5 degreee (celsius). Hard drives are 40 - 44 c. Fan System < 893 ...
cmchoi
Nov 13, 2012Aspirant
My Pro 6 temperature under normal load:
Temp SYS 55 C / 131 F [Normal 0-65 C / 32-149 F]
Temp CPU 30.5 C / 86 F [Normal 0-85 C / 32-185 F]
Is this normal? It seems it is 5 degree higher then norm.
